question
Benjamin W. avatar image
Benjamin W. asked ·
Broken PurePaths in Adobe AEM
When instrumenting an Adobe AEM (formerly CQ5) instance, PurePaths break between the Dispatcher and the Renderer. How can this be fixed?
configurationtransactionflow
1 Answer
Benjamin W. answered ·
If you’re using AppMon to follow transactions through AEM and you’re using a Dispatcher / Renderer setup, you need to whitelist the x-dynaTrace-header in the Dispatcher to allow transaction following through the Dispatcher to the Renderer.
Whitelisting HTTP headers is described in https://helpx.adobe.com/experience-manager/dispatcher/using/dispatcher-configuration.html#SpecifyingtheHTTPHeaderstoPassThroughclientheaders.
Share
