question
HIMANSHU m. avatar image
HIMANSHU m. asked ·
Can we increase log level in Appmon DB Query Monitor Plugin ?
Hi Guys,
we are facing some failures in DB queries executed via DB monitor plugin in Appmon.
Please help me know if there is a way to increase loglevel so that we can troubleshoot in a better way .
Himanshu Mor
pluginsappmonsaas
1 Answer
James K. avatar image
James K. answered ·
Server settings -> plugins -> select the plugin to open the configuration and at the bottom change the logging level. Of course how much is added by changing that depends on how the plugin was coded.
James
1 comment Share
Thanks @James K. !
0 Likes 0 · ·
