question
Carl A. avatar image
Carl A. asked ·
Chart data missing in Excel format reports in 7.1
I've tried every report options in 7.1, but I am unable to export detailed data along with charts in Excel reports, as available in previous versions. It now only exports one summary line per series, but not the chart values, which was useful in several reports for us. The only way I've managed to include this data it is to manually paste it from a separate CSV export, which will be tedious for frequently used reports.
Why was this data removed from Excel reports?
Here is a screenshot from a report in 6.X:
Thank you.
appmon7.1reports
Karel V. avatar image
Karel V. answered ·
I have a simelar problem after upgrade from 6.5 towards 7.2. I'm missing the Chart Data when reporting a Percentage Chart in Excel. Does anybody has a solution for that ? I found a work arround by using a CSV report, but the colom 'timestamp', that was a counter from 1 to 100 before is completely wrong. The data in the value column however is correct, so i have a (no a gracedull) workarround.
Share
Stefan K. avatar image
Stefan K. answered ·
Hi Carl,
maybe you have already solved it, but I found this solution which worked for me:
https://answers.dynatrace.com/spaces/148/uem-open-...
Best regards,
Stefan
Share
