question
ROBERTA D. avatar image
ROBERTA D. asked ·
insertion cookie
HELLO
to insert cookies on dynatrace can you use google analytics or motomo?
dashboardalerting6.5agent6.3administration7.1installationauto-detectionsensordocumentationadk6.2apachemigrationandroidperformance warehouse6.1phpsensorsappmonsaashybris
1 Answer
Joe H. avatar image
Joe H. answered ·
Roberta, If you're asking about AppMon UEM, there's much more to User Experience than just cookies and tags. AppMon UEM quantitatively measures the full user experience, something a simple cookie can't do. UEM is based upon javascript. The Javascript is just a .js file and can be hosted by a CDN or injected manually into the HTML using whatever Content Management system of choice, or simply let AppMon do it automatically.
Share
