question
akshay s. avatar image
akshay s. asked ·
Unique user count from AppMon
Can we get unique user count for an application from AppMon?
As of now, we are providing it through one business transaction which is having username splitting but if data is fetched for previous months it will have huge discrepancy in result if compared with current month.
Warm R,
AK
appmondashboardappmon 77.1measuresperformance warehouseknowledge sharingunique users
1 Answer
Rishabh Y. avatar image
Rishabh Y. answered ·
Hi @akshay s.
i am a bit confused as to what is the requirement and i would request for more clarity on it.
Not sure if this would help you in any way but the data which was stored in the performance warehouse would have lost it's granularity so i suppose that is the reason you are facing discrepency in the result when compared.
Rishabh
4 comments Share
Hi Rishabh,
Thanks for your comments. I also agree with your opinion. High resolution data might got converted to medium resolution data due to aggregation applied.
Do we have any other way to get unique user count? I can see one RFE is raised but some people are using following approach as well.
-->Implementing business transaction row counter plugin which at least give the count of unique rows.
I tried to configure the same but result is not as desired. The query is posted over the forum but didn't received any response yet.
Link is here.
Have you tried something like that?
Warm R,
AK
0 Likes 0 · ·
Hi @akshay s.
yes this approach can also be used to keep the data for longer period of time.
Will check this on my test bed then for more clarity.
regards,
Rishabh
0 Likes 0 · ·
Sure. Will wait for your inputs.
Warm R,
AK
0 Likes 0 · ·
Hi Rishabh,
Have you got change to implement below?
Warm R,
AK
0 Likes 0 · ·
