question
Satish M. avatar image
Satish M. asked ·
MQ Queue Channel Monitor - Measure Value Issue
I am using MQ Queue Channel Monitor plugin with AppMon 7.1. When I am executing this plugin it fetching data correctly but gives multiple values for same metrics as shown below.
See the hided part is IP of dynatrace collector,so is this value correct? Because CURRENT_SHARING_CONVS are 3 and three times one are for dynatrace collector.Since I am plotting this metrics in Dynamic Measures Matrics,I need to give justification for each value.
Kindly help..
Satish
extensionsmonitoringmq
1 Answer
Satish M. answered ·
Also I have given * to fetch all available channels information but getting only one channel. What changes need to do to get rest of channel information.
Share
