question
Muhammad N. avatar image
Muhammad N. asked ·
Delete All Method Sensor
I have some method sensor as active and start purepath, and the sensor work correctly start purepath by method that I pick.
But now all of method sensor has been delete by me and I apply it, because the flow of transaction (in purepath tree) being cut off per method. Are purepath will normal (back to default) again when the app restarted ??
Nasrudin
appmon7.0javaweb services
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Muhammad N.
First you can try the Hot Sensor Placement otherwise restart the Application Process to make the new Method Sensor Rule effective.
Babar
2 comments Share
Hi @Babar Q.
I can't try the hot sensor placement because application team does not allow me to do this. I still waiting for app restarted.
Are the purepath will be normal again when all method sensor has been delete ??
Nasrudin
0 Likes 0 · ·
Hello @Muhammad N.
Yes. It should fix the situation you are facing.
Below is the recommendation by Dynatrace.
PurePath length should not exceed 300 for production, 500 for test center, and 1000 for development. The impact of long PurePaths include higher CPU load on the monitored application or on the Server with higher MPS numbers, and shorter live session due to an implicated higher MPS.
Babar
0 Likes 0 · ·
