question
Rishabh Y. avatar image
Rishabh Y. asked ·
Does Dynatrace supports Mulesoft 3.9 ?
Hi Community,
Does dynatrace supports Mulesoft 3.9? If yes then could you please point me to the documentation or the link stating that.
In the documentation I can see it from 3.0 to 3.8
+how can i instrument the agent on Mulesoft ?
thanks in advance,
Rishabh
appmonconfigurationagent7.0appmon 7user session monitoringinstallationdocumentationknowledge sharing
1 Answer
David N. avatar image
David N. answered ·
Hello Rishabh,
If there is currently support for Mulesoft 3.0-3.8 I assume that 3.9 is on the Dynatrace roadmap for support. In the link below you can see that they have begun working on the Java agent to capture headers in Mule 3.9.0:
https://www.dynatrace.com/support/doc/appmon/release-notes-7-0/release-notes-7-0-33/
Here is some information on special modifications you have to do to monitor Mule applications. Other than what is listed here you should not have to other configuration changes to the regular agent installation process.
https://www.dynatrace.com/support/doc/appmon/installation/application-integration/mule-esb/
Hope this helps,
David Nicholls
1 comment Share
David,
Am I right to assume this isn't yet available for Dynatrace OneAgent?
0 Likes 0 · ·
