question
Saranya N. avatar image
Saranya N. asked ·
If the license expired for Dynatrace AppMon and later the new license was installed, will teh agents require a restart to connect?
Coz Im not seeing any agents on Client after applying new license. Just wondering if thats related to license applied too late.
appmonlicense
1 Answer
Kyle K. avatar image
Kyle K. answered ·
It would depend if instrumentation was already enabled or not if so then you should be fine if not then yes you would require an app restart.
Share
