question
ebru c. avatar image
ebru c. asked ·
Pure Path does not show
I can't see the pure path details on one of the IIS application. Attached is the screenshot. The agent looks healthy (although does only show as .Net agent on monitoring overview, can't see IIS.)
Agent looks OK.
appmon7.1dotnetiis
1 comment
Hi Ebru,
From the agents overview snapshot I don't see the IIS agent, AFAIK IIS and .NET agents will show separately in the agents overview. Have you followed these steps in instrumenting the IIS server
https://www.dynatrace.com/support/doc/appmon/shortlink/id_microsoft_iis_web_server_agent_configuration#configure-the-iis-module
Ravi
0 Likes 0 · ·
Ravi K. avatar image
Ravi K. answered ·
Hi Ebru,
From the agent overview snapshot which you have provided I could see the purepaths are getting captured on one of the slave agent - the purepath count is 49. so you can see the data.
I believe you are selecting the proper system profile under the Monitoring default Dashboard, if it is so then you need to make sure the time frame which you have selected as well. Paste me the snapshot on which you are looking for the data, if it's not helpful.
Ravi Kumar
Share
ebru c. answered ·
Hi Ravi, thanks for the doc. I have added the missing permissions on the folders. I can see the IIS and .NET agents on the agent overview -attached. But the monitoring dashboard does not show anything. Is there any specific log I should check?
Share
