question
Suganya N. avatar image
Suganya N. asked ·
Importing Additional License in AppMon
Hi All ,
We already have a license key in AppMon with 20 webserver , 10 Java etc and we got additional 10 JAVA agent license in a separate license key .
If i import the new license file will the old license will still be valid , i mean will the JAVA agents becones 10+30 = 30 and webserver 20 or
The old license should be combined with a new one to a single license file with the help of support and i should import it ?
Thanks & Regards ,
Suganya N
7.0appmon 7license
Ravi K. avatar image
Ravi K. answered ·
Hi Suganya,
If you are importing a new license file as per my knowledge it will disable the previous existing license and enable the current one, So in order to merge the two license you need to work with the license management team get single license file and apply then.
Note: Raise a support case with the licensing team who will help on merging the licenses which I did in my earlier cases.
Ravi Kumar
Share
Babar Q. avatar image
Babar Q. answered ·
Hello @Suganya N.
The license file should be one as per my understanding.
Babar
Share
Suganya N. answered ·
Thank you Babar and Ravi , i will contact licensing team .
Share
