question
Sreedhar M. avatar image
Sreedhar M. asked ·
Is it possible to filter the users based on the type of mobile data ?
hi All,
Recently we have received oone requirement to chekc if its possible in Appmon to filter the users of Mobile Browser based on the type of data they are using.
Example: User using Mobile Browser and whether usieng mobile data or wifi? If mobile data then whether 3G/4G.
Is this possible in Appmon?
Sree
7.0appmon 7mobile monitoring
1 Answer
Mathieu C. avatar image
Mathieu C. answered ·
Yes but just for Mobile App :
https://www.dynatrace.com/support/doc/appmon/user...
For Mobile WebView, you can try to create a BT of Visit by connection type but the only result seems to be Dial up, DSL or Broadband.
Connection Type :
Shows the visit's network connection classification. If detected for the JavaScript Agent, the network bandwidth is shown in braces. However, the Mobile Agent only detects connection and network type. Because of the impact on user data plans, the bandwidth value is not calculated and does not display for mobile applications. Since network contribution uses the bandwidth in its calculation, it is also not determined.
Mathieu
Share
