question
Hemakumari B. avatar image
Hemakumari B. asked ·
CPU Utilization spikes
Hi ,
I have enabled the WCF services agent in Appmon,After enabling agent we are getting large cpu spikes alerts
Could you please tell me cpu spikes is related to WCF services.
Thank you
Hema
configurationagentservices
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Hema k.
The .NET Agent Configuration tool can cause small CPU spikes every ten seconds when open.
Auto Sensors adjust automatically to ensure they do not incur more overhead than the percentage setting. The amount of detail captured depends on the complexity of the application or environment. You may need to adjust the resolution settings until you see the desired level of detail for a tolerable amount of overhead.
Have a look on the below link for more insight.
https://www.dynatrace.com/support/doc/appmon/admin...
Babar
Share
