question
Konstantin M. avatar image
Konstantin M. asked ·
Monitoring of DB job executions
Is it possible to monitor for failed Database job executions via Dynatrace? Database is MSSQL and question is related to job manager of MSSQL.
databasesplunk
1 Answer
David N. avatar image
David N. answered ·
Hello Konstantin,
You can use the Database agent to get more insight into how your MSSQL database is operating.
Here is more information on that agent and the kind of information it provides.
https://www.dynatrace.com/support/doc/appmon/database-monitoring/?_ga=2.241076939.912036122.1539616226-1967624720.1534795578
David Nicholls
Share
