question
HIMANSHU m. avatar image
HIMANSHU m. asked ·
Incidents in Appmon Web dashboard
Hi Guys,
is there a way to see incidents in appmon web dashboard?
Himanshu Mor
web dashboardappmonsaas
1 Answer
Ramesh N. avatar image
Ramesh N. answered ·
Hello Himanshu,
There is no out-of-box incident dahsboard in web.
But you can create one. Follow below steps
select "Show Navigation"--> click on my dashboard --> Add dashboard --> edit tile --> select alert tile --> click on Add alert rule --> search & select required incident alert (you can select multiple or add different dashlet)
Cheers
Ramesh
2 comments Share
Thanks @Ramesh N. ! This helps!
0 Likes 0 · ·
Grt!
Cheers,
Ramesh
0 Likes 0 · ·
