question
Hemakumari B. avatar image
Hemakumari B. asked ·
Enabling WCF sensors
Hi Team,
Can you please explain is there any option in appmon to enable few wcf sensors?
Hema
appmongood to knowweb performance monitoringsensorwebserversensorsweb services
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Hemakumari B.
You can enable the sensors from the Sensor Placement. Follow the instructions from the below link.
https://www.dynatrace.com/support/doc/appmon/admin...
Babar
Share
