question
trung d. avatar image
trung d. asked ·
AppMon 6.5.0.1289 How to disable HTTP TRACE method?
DIAGNOSIS
The remote Web server supports the TRACE and/or TRACK HTTP methods, which makes it easier for remote attackers to steal cookies and authentication credentials or bypass the HttpOnly protection mechanism. Track / Trace are required to be disabled to be PCI compliance.
CONSEQUENCE
If this vulnerability is successfully exploited, attackers can potentially steal cookies and authentication credentials, or bypass the HttpOnly protection mechanism.
How do I disable HTTP trace method on my Dynatrace server port 8040, 8041, 8042, 8043?
Thank you for your time.
security
1 comment
Hi Trung,
Are you able to fix this issue.Can you please let us know if you got any fix.
Tarun
0 Likes 0 · ·
1 Answer
trung d. answered ·
Upgrade AppMon to 7.2 and the problem is fixed.
Share
