question
Dennis H. avatar image
Dennis H. asked ·
Specific Message Flow name monitoring in AppMon
We are currently monitoring using the Websphere Message Broker plugin. We have alerts in place for the Message Flow as a whole - can someone please assist in setting alerts for specific flows within. For example - we have alerts set DYNT_1265 for any message flow. However, I want another alert to go to a different team specifically when the *.missdig* flow is down (blue arrow). Thanks!
messagebroker
1 Answer
Ramesh N. avatar image
Ramesh N. answered ·
Hello Robert,
May we know which plugin you are using for incident alert? Plugin " Extended Mail Action Plugin" (best used for customization)
Create new "Method" measure which will contain/equal your class : com.xx.missdig
Now create another/Copy alert DYNT_1265 & add new measure (which will have filter of com.xx.missdig) with AND logic in it.
In action set your mail alert recipients.
Cheers
Ramesh
Share
