question
Jo R. avatar image
Jo R. asked ·
Where would one find a glossary of icons and their meanings
appmon6.5
Rodrigo A. avatar image
Rodrigo A. answered ·
I think the answer that Babar gave to Julia is exactly what you are looking for:
The Tree tab of the PurePath dashlet displays the contributors to the PurePath, selected in the PurePath tab, arranged as a tree that maps the calling hierarchy of the contributing methods.
The call hierarchy of the selected PurePath can span multiple threads or processes, depending on the applied sensors. To indicate thread or process changes within a PurePath, the following special nodes are inserted within the tree view:
  • Synchronous Path
  • Asynchronous Path
  • Asynchronous Invocation
Have a look in the below link for more insight.
https://www.dynatrace.com/support/doc/appmon/application-monitoring/appmon-client/dashlets/purepaths-dashlet/tree-tab/
So if you access the link you will see the explanation of each element. For example in the pic, you can see the invocation to Sync and async invocations, both with yellow arrows but they mean different types of calls
Regards
Share
Satish P. avatar image
Satish P. answered ·
digging old thread.. to repeat the question, what are the various icons in the PP tree? for example, i see a yellow right arrow before the method name.. it means..?
Share
Julia S. avatar image
Julia S. answered ·
Still waiting for it! I can see the Purepath icons on the Documentation, but for the Purepath TREE icons I cannot find anything!
1 comment Share
Hello @Julia S.
  • Synchronous Path
  • Asynchronous Path
Babar
1 Like 1 · ·
Radosław J. avatar image
Radosław J. answered ·
You mean icons that appear next to Purepaths in Dynatrace?
R.
1 comment Share
purepath tree to be exact
1 Like 1 · ·
Mathieu C. avatar image
Mathieu C. answered ·
For AppMon, you have some informations in the documentation :
Example for Purepath :
https://www.dynatrace.com/support/doc/appmon/appl...
Mathieu
1 comment Share
This one I found before - sorry I didn't add the URL; looking for the icons that appear in the PP tree
1 Like 1 · ·
