question
Ramesh N. avatar image
Ramesh N. asked ·
JSON :: Reporting plugin (DT AppMon 6.5.4.1014)
Hello All,
Currently we are running with dynatrace appmon v6.5.4.1014 (soon will upgrade it)
We have imported JSON plugin into dynatrace & we are not able to find it under reporting.
Also tried to check in debug mode still not able to see JSON format.
Thanks in advance.
@dominik.stadler
- Ramesh
6.5extensionsplugins
Radosław J. avatar image
Radosław J. answered ·
I also suggest you upgrade Dynatrace to version 7.1 or 7.2.
It is worth knowing that in a moment version 7.0 will stop being supported.
Share
It seems that i had the same issue like you. I give you simple workaround to that problem;)
1. Restart Dynatrace Server and Client
2. Please enable /debug-mode/ via CTRL-SHIFT-F9 to show new options in the Reporting-dialog
It works for me :)
1 comment Share
Hello Radek,
Thanks for your reply.
I tried to check using debug mode. Still I cant see json format.
Ramesh
0 Likes 0 · ·
