Answer by James K. ·
I think using the top web requests diagnostic tool with the applicable filters applied would give you that information:
Answer by Sebastian K. ·
You can always create multidimensional view on service page. There you will be able to filter requests by URI and method.
Answer by Wolfgang B. ·
Can you give me some context on what exactly is your use-case here? Do you mean incoming API POST requests to Dynatrace or is this question related to monitoring your own requests?
Thanks for reply.
That mean Incoming API posts for particular request.
If possible it would be great if you filter on the form post data:
Example:
form posts to: https://www.facebook.com/pages/
If the filtering is not possible can we do an export of all the requests including post data into excel?
