DTXAction max name length
matthew_rees
Newcomer
We are using the One Agent SDK for iOS. Everything is reporting nicely but we are using a custom DTXAction to track web service calls. We are using the urls as the action name but due to our crazy long urls lengths often 300 characters +. These are being truncated is there a max character length on this field and if so what is it?
Patrick_H
Dynatrace Champion
Dynatrace Champion
why do you use actions to wrap the webservice calls? http request shoudl be instrumented automatically
iOS help: https://www.dynatrace.com/support/help/shortlink/ios-hub
