• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Simone N. · Nov 17, 2018 at 01:53 PM · 7.0 business transaction measures
Counting WebRequests with specific parameters
we have created a BT in which the filter is a measure of the type "web requests - parameter value (Business Transaction Evaluation/Filter/Splitting Values), as follows.
Now our scope is defining an incident based on how many times this specific BT is called, so i can't use the measure "WebRequest Count" because Ineed to count not only the URI, but also the parameters included in the URI. We don't find a way to implement this feature, could you help us in solving this problem?
Thanks in advance
Simone
Comment
People who like this
0 Show 1
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
avatar image Alexander R. · Nov 19, 2018 at 08:21 AM 0
Share
Hello Simone,
I tried to add simple counter in BT as your described and there was no result. Maybe i had reproduced something wrong.
If it is only need for incident - you can copy your measure and set another threshold: for example 5, and then you can create incident rule.
If technical users want to investigate the indecent they will use your configured Business Transaction. You will have incident rule and BT.
  • Sort:
  • Most voted
  • Newest
  • Oldest
Welcome to the
Dynatrace Community Forums
Check out the Community User Guide and First steps in the forum to learn how to get started.
Community Member of the Month
December 2019
Announcing Dynatrace's Community Member of the Month for December 2019, Enrico F.! Click here to read more!
Employee Member of the Month
December 2019
Announcing Dynatrace's Employee Member of the Month for December 2019, Silvia M.! Click here to read more!
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 12, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
33 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
retrieve metadata from a page using UEM 2 Answers
No output for BT- Troubleshooting methods 0 Answers
built in business transaction works but the sameone customized doesn't 3 Answers
Meaning of aggregation LAST in Login TOTAL TIME Calculation Businee Transaction 2 Answers
create a measure based on the domain of a UA 0 Answers
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api errors dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java browser agent community user guide hybris javascript appmon sensors good to know search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow diagnostics user session monitoring unique users continuous delivery configuration alerting NGINX splitting business transaction client 6.3 installation chart database scheduler apache mobileapp RUM php dashlet azure purepath plugins agent 7.1 appmonsaas messagebroker nodejs 6.2 incidents android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
