question
Akshay P. avatar image
Akshay P. asked ·
Not able to configure easy travel with dynatrace appmon 7.2 version Plese help
I am facing below issues after installing easy travel and running a sample test from it.
I have installed easytravel on port 9000 since on port jenkins is installed.
Please let me know if any other infor i can provide which can help in resolution of my problem
Error1:-
2018-12-11 15:21:08 Launcher WARN [BrowserSimulator] com.dynatrace.diagnostics.uemload.scenarios.easytravel.EasyTravelSimplePage@4c52ce2c org.apache.http.ConnectionClosedException: Premature end of Content-Length delimited message body (expected: 5122139; received: 2645870 at org.apache.http.impl.io.ContentLengthInputStream.read(ContentLengthInputStream.java:178) at org.apache.http.impl.io.ContentLengthInputStream.read(ContentLengthInputStream.java:198) at org.apache.http.impl.io.ContentLengthInputStream.close(ContentLengthInputStream.java:101) at org.apache.http.impl.execchain.ResponseEntityProxy.streamClosed(ResponseEntityProxy.java:143)
Error 2:-
2018-12-11 15:21:11 Launcher INFO [UemLoadHttpClient] The resource 'http://localhost:8081/dynaTraceMonitor' will not be loaded, because the hosting server is not responding 2018-12-11 15:21:12 Launcher INFO [UemLoadHttpClient] The resource 'http://localhost:8081/dynaTraceMonitor?info%3D%7Bo%3Ac%7Cvv%3A2%7Cb%3AeasyTravel+mobile%7Cc%3A324%7Cd%3A753%7Cg%3AWIFI%7Ch%3AeasyTravel+mobile%7Ci%3A720%7Cj%3A1280%7Ck%3A37.751007X-97.822%7Cn%3A802.11x%7Cp%3A-89%7Cu%3AAndroid+6.0.1%7Cv%3AQuad-core+1.6+GHz+Cortex-A7%7Cq%3AL%7Cs%3A1544521872557%7Cw2%3AMMB29M%7Cx%3A0.57448655%7Cy%3A102%7Cz%3A18.0%7D%7Bo%3Ab%7Cvv%3A2%7Cr%3A1%7Cc%3Aen_US%7Cd%3A0%7Cn%3A6.1.1234%7Cu%3A1234%7Cp%3A6.3%7Cx%3AAT%21*%21T%7D%7Bo%3Aa%7Cvv%3A2%7Ca%3ADisplay+SearchJourneyActivity%7Cb%3A35112%7Cc%3A35120%7Ce%3A5%7Cq3%3ASearchJourneyActivity%7Cr%3A6%7Cs1%3A47%7Cs2%3A48%7Cs3%3A49%7Ct1%3A35116%7Ct2%3A35118%7Cy%3A1778%7Cz%3A1777%7Cp3%3A0%7D%7Bo%3Av%7Cvv%3A2%7Cb%3A1544521837435%7Ck%3A810%7Cx%3AHTC%7D' will not be loaded, because the hosting server is not responding 2018-12-11 15:21:12 Launcher INFO [UemLoadHttpClient] The resource 'http://localhost:8081/dynaTraceMonitor?info%3D%7Bo%3Ac%7Cvv%3A2%7Cb%3AeasyTravel+mobile%7Cc%3A324%7Cd%3A753%7Cg%3AWIFI%7Ch%3AeasyTravel+mobile%7Ci%3A720%7Cj%3A1280%7Ck%3A37.751007X-97.822%7Cn%3A802.11x%7Cp%3A-60%7Cu%3AAndroid+6.0.1%7Cv%3AQuad-core+1.6+GHz+Cortex-A7%7Cq%3AL%7Cs%3A1544521872557%7Cw2%3AMMB29M%7Cx%3A0.045432318%7Cy%3A104%7Cz%3A9.0%7D%7Bo%3Ab%7Cvv%3A2%7Cr%3A1%7Cc%3Aen_US%7Cd%3A0%7Cn%3A6.1.1234%7Cu%3A1234%7Cp%3A6.3%7Cx%3AAT%21*%21T%7D%7Bo%3Aa%7Cvv%3A2%7Ca%3ATouch+on+Paris%7Cb%3A34563%7Cc%3A35122%7Ce%3A5%7Co%3A0%7Cr%3A11%7Cs1%3A50%7Cs2%3A51%7Cy%3A1777%7Cz%3A0%7Cp1%3ASearchJourneyActivity%7Cp2%3ASearchJourneyActivity%7Cp3%3A3538%7D%7Bo%3Av%7Cvv%3A2%7Cb%3A1544521837435%7Ck%3A698%7Cx%3AHTC%7D' will not be loaded, because the hosting server is not responding
appmononeagentservices
Joe H. avatar image
Joe H. answered ·
Be sure you're running the latest version of EasyTravel.
When you say that you're running EasyTravel on 9000, can you clarify what you changed? EasyTravel uses lots of different ports and it's not clear which one you changed to 9000.
1 comment Share
I am using easy travel version compatible with dynatrace appmon 7.2 from below link
https://community.dynatrace.com/community/pages/viewpage.action?title=Demo+Applications+-+easyTravel&spaceKey=DL
And in terms of port 9000 i haven't changed anything from my side. its just like i have installed easy travel app from above link and follow the process to make it completed installation.
Note :- After installation easy travel app is open but it asked me to configure application at port 8080 but i decline the request since jenkins is installed on that port.
Apart from above details i haven't done any thing extra from my side.
0 Likes 0 · ·
Joe H. avatar image
Joe H. answered ·
Ports can be changed for Easytravel by editing the properties file. From within the EasyTravel GUI, select the upper right corner Gear icon and select 'Show Properties'. Be sure to restart the EasyTravel GUI completely after editing this file.
I'm frankly not sure what is happening, EasyTravel tries to select listen ports in a range, You can edit that range (search for 8080). But if 9000 is clear, i don't see any reason it wouldn't run correctly. Maybe 8081 is blocked by something? Maybe "localhost' doesn't resolve correctly?
Share
