question
Michael D. avatar image
Michael D. asked ·
How do you capture a web service failure rate?
The image shows 5 web service calls for one purepath. Two of the web services failed, and the others succeeded. How do I create a measure that reports on the failure rates displayed in the web services dashlet?
web services
Radosław J. avatar image
Radosław J. answered ·
First way:
You can be able to right click on the interested Web Service on the 'Web Service' dashlet, and then select Create Measure.
Second way:
You can do this by editing your System Profile settings, going to Measures and selecting Create Measure.
Radek
Share
Michael D. answered ·
@Babar Q.
I believe that your suggestion is providing the failure rate of the entire purepath. I tried it and it's showing a 0% failure rate, even though the web services dashlet shows some web service failures. I'm looking for a way to monitor the failure rate shown on the web services dashlet.
Mike
Share
Babar Q. avatar image
Babar Q. answered ·
Hello @Michael D.
Right Click on the Web Service and choose 'New Business Transaction' the select 'Web Services - End Point Value' (Represents the calls of declared Web Service with a specific endpoint value within a PurePath) or Web Services - Method Value (Represents the calls of declared Web Service with a specific method value within a PurePath).
Once you have provided the measure name then on the bottom of the right hand you will find a split button so click on it and now provide the business transaction name.
It will automatically calculate 'Failure Rates' and 'Response Time and Count' for you.
Babar
Share
Neither option allows you to create a measure for web service failure rates.
Share
