question
dynatrace A. avatar image
dynatrace A. asked ·
Dynatrace Appmon - I has a plan to use CGroups
I has a plan to use CGroups (https://en.wikipedia.org/wiki/Cgroups) in our RedHat servers to separate resource between each jBoss running in the same server. Before doing so, I would like to know whether this would impact the monitoring part in Dynatrace and in which way, if any,
appmonappmon 7production7.2
1 comment
@sebastian k.,
0 Likes 0 · ·
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
I've not used this feature before but appmon agents are started together with processes. So agent instances should work in the same cgroup as particular process.
Share
