question
Ashutosh S. avatar image
Ashutosh S. asked ·
System profile sepration
I am using DT appmon 7.1 and i would like to separate out one system profile from existing server to new server due to heavy load on application. So here i would like to know steps to separate out a particular system profile with historical data of session storage as well as PWH.
How can i achieve this, kindly help me out with possible solution.
Ashutosh Singh
appmon 7serverperformance warehousesystem profile
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Hello, system profile can be just exported and imported to new server. Then you just need to redirect agents to new collector.
To migrate data I think you should use the same steps like for upgrading Appmon. Using migration-tool.jar , dumping performance werehouse
And setting it up on new instance and copying static files from storage. You will have to copy all and Dynatrace after some time will overwrite transactions from different system profiles.
But the question is how looks actually your setup. Maybe adding extra collectors that are working in HA will helps? Upgrading to Appmon 7.2 and switching to Appmon Agent is also one of the ways because data are sent via http and load for Iinfrastructure is smaller. How looks Dynatrace server? Can parameters be extended for it? Maybe this will be solution.
Share
