The api which we are using is as follow
https://localhost:8021/rest/management/dashboard/demo?purePathDetails=ALL&filter=tf:CustomTimeframe?1548054000000:1548054060000
Answer by supriya k. ·
Hi Sebastia,
There is REST available for purepath as mentioned by Babar.
We also want to extract the purepath method tree on XML which we are not able to do. We are using following api. Is there any other api to get this XML for Appmon
https://localhost:8021/rest/management/demo/?purePathDetails=ALL
In one minute time duration the number of purepath is more than 12000 maybe due to which we are not able to fetch large amount of purepath data. How can we handle this ???
You still didn't answer me :) How looks response you get from this endpoint.
Answer by Babar Q. ·
Hello @sebastian k.
I guess this is still available. Have a look on the below link?
https://www.dynatrace.com/support/doc/appmon/appmo...
Babar
You’re right i’ve Support for purepaths in plugins development during incident was dropped. My bad :)
Answer by Sebastian K. ·
As I now, purepath are no longer supported by REST (if I'm wrong, please correct me).
