question
David D. avatar image
David D. asked ·
Mobile ID's on appmon_What are the ways to pass the visitors ID?
I'm trying to determine what needs to be included in the mobile code to pass the id so it is visible in the visits. I'm not seeing any documentation on it. And since it is in the code, can I still use the Visits Tag within the UEM configuration for the Browser user ID being passed in my request header? Would anybody be able to help answer these questions. Thanks! -David
mobile monitoring
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
there is no special peace of code for setting user login. But you can create user action with user name, and then create measure that is exctracing value from this. Then you should be able to use it as tag. More info:
https://answers.dynatrace.com/questions/196949/add...
Share
