question
Karthikayini M. avatar image
Karthikayini M. asked ·
Dynatrace APM Client not opening
Hi All,
I am getting below error in client machine. Not able to open client. Please help me.
Thanks & regards
Karthikayini M
java7.1clienterrors
Babar Q. avatar image
Babar Q. answered ·
Hello @Karthikayini M.
First of all run the command java -version on the command prompt to know the availability and version of Java.
If you do not have a Java then install it the version required by Dynatrace Client and then in the Advanced System Settings assign a veriable e.g.
Babar
1 comment Share
Hi @Babar Q.
Thanks for the reply.
Regards
Karthikayini M
0 Likes 0 · ·
Sebastian K. avatar image
Sebastian K. answered ·
Client has Java installed properly on his station?
2 comments Share
HI @sebastian k.
Could you please tell me, java of local machine ?
Thnaks & regards
Karthikayini M
0 Likes 0 · ·
Yes this error tells us that there was a problem with finding java by client.
1 Like 1 · ·
Joe H. avatar image
Joe H. answered ·
The client installer installs a private JRE into the Dynatrace directory already so there should be no reason to have to install a Java Runtime.
If you're still having problems, perhaps you should uninstall and then reinstall the client.
Can you clarify whether you're using locally installed client, or the JNLP client?
3 comments Share
HI @Joseph M. H.
Thanks for replying.
I am using portable client. Should I delete and use new client.
Thanks & regards
Karthikayini
0 Likes 0 · ·
I suggest you delete the client you have and install the full client from the downloads page. It will install a JRE for you as part of the client install.
https://downloads.dynatrace.com/downloads/download.aspx?p=1&r=219
0 Likes 0 · ·
Hi @Joseph M. H.
Regards
Karthikayini
0 Likes 0 · ·
