question
Nima S. avatar image
Nima S. asked ·
How can i Capture request header cookie with AppMon?
I want to Capture a Request Cookie. I tried the solutions i found in forum but it still doesn't work.
I just want to measure the count of hbMarketCookie
It couldn't capture any headers.
Greets,
Nima
purepath7.2sensors
Mevlüt S. avatar image
Mevlüt S. answered ·
Hello Nima ,
  • The first thing you need to do that is define request header value in servlet/webserver. Go to System Profile Settings > Web Server > Sensor Configuration > click WebServer/Servlet edit > Define request header here (Source: Request Header, HTTP Header and parameter: Cookie) then click save.
  • After that, you should create a Request Header measure(not response header, if you want to capture request header.). Header field: Cookie, Value: Begins with hbMarketCookie, and don't forget to set num value: 1.0 !
  • Finally, you should create a BT and add the measure in it. (İf you select user action instead of server-side purepath, you can calculate the count of user action) Then no splitting and calculate result value.
Best Regards.
Mevlüt
Share
Sebastian K. avatar image
Sebastian K. answered ·
You have to capture whole cookie header and extract value via regex:
https://answers.dynatrace.com/questions/217162/how...
Share
