CA CMDB integration with Dynatrace Managed
melissap
Guide
Hi
Is there an integration or api that can talk to CA CMDB from Dynatrace Managed?
franz_soengen
Inactive
Hi Melissa,
there is no out-of-the-box integration for CA CMDB. You can get all the Smartscape data with the Topology and Smartscape API though:
https://www.dynatrace.com/support/help/extend-dyna...
best regards
Franz
