question
Jack G. avatar image
Jack G. asked ·
Can I compare data from a time period between 07:00 and Now with the same time period yesterday?
Hello
I want to create a dashboard that displays data as it is being collected from 07:00 to the current time and compares this data with the same time period yesterday. I am getting 'comparison timeframe not available' as it is trying to show data from 07:00 yesterday to now. I want this graph to show data from 07:00 yesterday until this time yesterday.
Is this possible?
dashboardmonitoringappmon 7production7.2web dashboarduser actionsdashlet
David N. avatar image
David N. answered ·
Hello Jack,
I don't think it allows comparisons when the timeframe for the chart is set to a custom time ending now because the chart would have to keep updating and the comparison metrics would also have to keep updating at the same rate. If you create a chart with a timeframe that ends at a specific time you would be able to perform the comparison. The current way you are trying to do it creates a situation with some very intensive operations occurring at regular short intervals so it is not allowed.
David Nicholls
Share
Jack G. answered ·
Thanks for the response @David N.
I have set the dashboards to run to last 6 hrs now and set comparison graphs to run at last 6hrs - 1day. Doesn't give exactly what I want but shows the comparison.
Share
