question
Sjoerd B. avatar image
Sjoerd B. asked ·
UFO_Alerter plugin created for AppMon 6.5+
Hi all,
I needed a simple way to use the UFO's with AppMon, and since I didn't see a simple REST action in the library, I created a UFO_Alerter action plugin.
The first version works (not too difficult; have a look at the code), and I thought maybe the community would like to share and re-use the plugin.
If you're not satisfied with my work or see bad coding mistakes, please fork and maybe do a pull request if you adapted stuff...
The github url (where also a built version of the jarfile is available): https://github.com/ictcorebiz/Dynatrace-AppMon-UF...
Of course using is at own risk, etc, etc, etc as mentioned in the MIT license :)
appmonextensionsplugins
