question
Karthikayini M. avatar image
Karthikayini M. asked ·
Automatically connected to performance warhouse after migration-2 dynatrace servers connected to same DB
Hi All,
After migration dynatrace automatically got connected when made services up and connected to local host.
Right now my old and new servers both got connected to same performance warehouse.
What is the impact. How to avoid it.
For testing purpose only I made services up and was testing but default old DB got connected.
Please help me
Thanks & regards
Karthikayini M
7.07.1migrationperformance warehouse
1 Answer
Shane K. avatar image
Shane K. answered ·
Per the migration guide, you should have shut down the old instance prior to bringing up the new instance. Your best option now will be to open a support case.
Share
