question
sai b. avatar image
sai b. asked ·
How to pull rest api with authentication token in appmon 7.2
I want to pull rest api details without username/password authentication propably by authorization token or any other way so that these rest apis can be called as a service is there a way to achieve this in appmon 7.2
rest api7.2android
1 Answer
James K. avatar image
James K. answered ·
No, AppMon only uses BASIC authentication. There is no token based authentication mechanism.
https://www.dynatrace.com/support/doc/appmon/shortlink/id_server_rest_interfaces#authentication-and-authorization
James
Share
