question
Daniel M. avatar image
Daniel M. asked ·
INSTALL_FAILED_DEXOPT when trying to install auto-instrumented multidex android application
Hello,I am having trouble with auto-instrumenting our multidex android application. The build succeeds with instrumentation, but I get a INSTALL_FAILED_DEXOPT error when installing.I've tried setting properties in the gradle plugin as follows but still get the same issue:agentProperties 'DTXLogLevel': 'debug', 'DTXPrimaryDexLimit': '60000', 'DTXSecondaryDexLimit': '60000'
android
Daniel M. answered ·
Clean/Rebuild and wiping my fire stick did not help. I'll open a ticket.
Share
Thomas W. avatar image
Thomas W. answered ·
Maybe there was a problem in the build. Can you verify that the problem still exists, when you perform the following steps: Clean + Rebuild the app. Wipe the data from the emulator and then install the APK
If the problem is not gone, then you should create a support ticket. Please provide the following information in the support ticket:
* Is Instant-Run deactivated?
* Is R8 deactivated?
* On which device/emulator does the problem occur?
* What is the "targetSdkVersion" value of your app?
* Which agent version are you using?
Share
