question
Karthika l. avatar image
Karthika l. asked ·
Measure to capture javascript error message
Can any one let me know if we can capture java script error message for particular flow in my complete site.
I have created BT with measure from UEM(user Action heath - error detection) client error to capture the error count but need to get the javascript error message in dynatrace Appmon.
appmonDynatrace Managedappmon 7user session monitoring7.1javascriptuser actionsappmonsaas
Swathi P. avatar image
Swathi P. answered ·
Is it confirm that only getting count of javascript error is possible and not the error message?
Share
Dave M. avatar image
Dave M. answered ·
I believe you can only access that data in the Client Errors dashlet. If you go there and drill down to a User Action PurePath to a JS error and right click you will see that Create Measures is greyed out.
Share
