question
Ozgur E. avatar image
Ozgur E. asked ·
Rabbit MQ Monitor Plugin for AppMon
I have a question about the Rabbit MQ Monitor Plugin which version is 6.2.2.5. I did all of the plugin configuration on AppMon Server include schedule RabbitMQ Monitor. But when ı tried to get meauseres that Messages Ready and Messages from RabbitMQ via rest api, it didn’t work. Only I receved “null” every time. I guess the Rabbit MQ Monitor Plugin for AppMon didn’t work as expected. So how can I fix it ? Do you have any suggestion ?
Best Regards.
Özgür İlyas Ekmekci
extensionsmonitoringmq
2 comments
Hi Ozgur E, did you ever get to the bottom of this issue? I have the exact same problem. Just wondering if you found the cause of the issue?
0 Likes 0 · ·
Hello, unfortunately I haven't resolved the problem. Rabbit MQ Monitor Plugin for AppMon hasn't any support from Dynatrace. I hope you will find the solution.
0 Likes 0 · ·
Ozgur E. answered ·
Hello Rodrigo,
I can confirm that Rabbit MQ is reachable from AppMon because when I tried to get the other measures which, came from default plugin, they did well. If I create specific measure for only one queue, It returns "null" value. I configured AppMon's Rabbit MQ Plugin exactly as mentioned in this link "https://community.dynatrace.com/community/display/... I attached my screen shot.
Thank you for helping.
Share
Rodrigo A. avatar image
Rodrigo A. answered ·
Hello Ozgur,
Have you verified that the Rabbit MQ is reachable from AppMon collector where you are running the plugin?
Also you could check the logs to find more information about why the call is failing.
Regards
Share
