question
Dan C. avatar image
Dan C. asked ·
How to configure default PurePaths Dashlet Analysis (Sort)
When selecting the PurePaths Dashlet from the AppMon Cockpit, or when Drilling Down from within a Dashboard to PurePaths it defaults to Sorted by: Slowest Result Limit:100. Can this default parameter be changed and saved as other values?
purepath7.2dashlet
1 Answer
Rodrigo A. avatar image
Rodrigo A. answered ·
One thing that you could do is create a dashboard with your custom filters and link the dashboard:
1) Create dashboard just with Purepaths dashlet.
2) Change the Sorted by and Result limit
3) Save the dashboard (For example fastest 100)
4) Go to the dashboards/dashlets where you want to do the drilldown with this filter, right click"dashlet properties" > "Dashboard links" > Add your new dashboard
After saving the changes you will be able to drilldown to the PP dashboard with the filters you have pre-selected "Apply filters to dashboard"
Regards
1 comment Share
Thanks for the information, this works perfectly for our process.
1 Like 1 · ·
