question
Shruthi B. avatar image
Shruthi B. asked ·
Register test run through restAPIs
We are using Jenkins for our tests which executes JMeter scripts.
Currently, we have added following dynatrace header in our JMeter scripts, NA=pTest-${__P(JOB_NAME)}.${__P(BUILD_NUMBER)}.${__samplerName()};TR=${__P(DT_TESTRUN_ID)};SN=${__P(JOB_NAME)}.${__P(BUILD_NUMBER)}.${__samplerName()}
Due to these headers, even local JMeter execution results in Tests being registered and populating the "Test Results" tab.
Is there a way to register tests as an option where only valid tests are registered via REST APIs and the rest are discarded?
rest api7.1test automation
Shruthi B. answered ·
Due to TR=${__P(DT_TESTRUN_ID)}, the value of TR gets set to 1 if no DT_TESTRUN_ID is available.
The server log shows following entry
2019-04-16 21:50:21 UTC INFO [TestRunHandler] TestRun '1' not found or uuid is not valid - using current TestRun 'ee10a62a-381f-4a13-87fd-0b35cced229d'
I tried to set TR=${DT_TESTRUN_ID} where the variable value is blank if DT_TESTRUN_ID is available.
The HTTP header shows
X-dynaTrace: NA=pTest-DT_Test.1.ilp-login-mgr+ || /services/logon;TR=;SN=DT_Test.1.ilp-login-mgr+ || /services/logon
But the log shows
2019-04-17 01:20:48 UTC INFO [TestRunHandler] TestRun '${DT_TESTRUN_ID}' not found or uuid is not valid - using current TestRun '03a4bfa8-0ba9-4607-abcb-25066c8276e6' [log message will be suppressed for 10 minutes]
Where do these test Run Ids get auto-generated?
Share
Hi @João V.
The preProcessor will be required for each Http request. We have tests with multiple transactions and each transaction might have 1-20 http requests. Is there a way to add a sampler and push it to each HTTP request header?
Shruthi
Share
João V. avatar image
João V. answered ·
Hi @Shruthi B.
This configuration is available in Jmeter BeanShell PreProcessor, you can identify origin of the execution and add conditional to add or remove headers;
You can create variables to identify the local environment and the jenkins environment;
http://jmeter.apache.org/usermanual/component_refe...
I Hope have helped!.
Best,
João Vilacia.
Share
