question
Karthika l. avatar image
Karthika l. asked ·
Fragment url- after # Not captured in measure
I am currently working on appmon version .We need to use a filter measure which restricts below sample page:
testa/index.html#test
If I add a regex (.*/index.html#test.*) the Measure is not working as expected and it's not considering the value after #.
Can anyone let me know the possibility to capture fragment url (including elements after #)content in measure
appmonDynatrace Manageddynatrace saas
Karthika l. answered ·
Thanks for your reply
I have tried this, it is working fine in test regex of measure but the Value is not getting captured in BT.
As the hashtag url doesnt consider the values after #, it is not picking in BT.
Share
Rodrigo A. avatar image
Rodrigo A. answered ·
If you just want to capture that value, try with this one (\/index.html\#test)
You use backslash to escape weird characters.
Also keep in mind that you can test your regex by clicking on the lightbulb icon.
Share
