question
Mohammad E. avatar image
Mohammad E. asked ·
How to sync two system profiles under different Dynatrace Servers?
system profile
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
You can use import / export options. There is no automatic process for that. I myself do changes on test. After confirming it I'm copying for example business transaction and add sensor packs to right agent groups. But if all namings perfixes etc are the same you can export SP from one server, On second one you can import it manually.
Share
