question
colin d. avatar image
colin d. asked ·
Appmon 6.5 client can't connect to server
Hello community.
the Appmon 6.5 client can't connect to server .
I have tested update the version to the 6.5.37 .but It is not worked. only by restart the server and collector ,can the client connect to the server successful.
but it will failed again in the next time.
telnet <ip> 2021 is ok!
please help me!
thanks and regards
colin
appmon6.5
Rodrigo A. avatar image
Rodrigo A. answered ·
Hello Colin,
You can try to use the Webstart client https://your.dynatrace.server:8021/, download the webstart and verify if with this one is working fine. Also would be a good idea to open a client in the machine where the AppMon Server is running, to verify that there are no firewall rules that could affect the connection.
Also, as a side note, it could be a good time to think about upgrade your AppMon installation to moderns versions, as 6.5 is out of support since September 2018
https://www.dynatrace.com/support/doc/appmon/relea...
Regards
1 comment Share
hi,Rodrigo:
the problem is cpu usage is too high !
after restart the process about 2 days,it will comsume cpu too high again. So,client can't connect to the server
memory and disk seems ok!
The cpu is 8 cores , 64G memory.
how can I do to solve the problem ?
Colin
0 Likes 0 · ·
Christian W. avatar image
Christian W. answered ·
Hello Colin,
Is there probably a firewall blocking the port?
Christian
1 comment Share
No,firewall is ok
the problem is CPU usage is too high
0 Likes 0 · ·
