question
Godfrey A. avatar image
Godfrey A. asked ·
Can I use appmon to integrate "problems & event notification" with 3rd party notification tools like I can with dynatrace managed Integration with dynatrace API?
appmon 7
Godfrey A. answered ·
thanks Sebastian, yes we are using a product called Solace PubSub+ and we are asked to publish events and problems to a specific message queue or Topic using Dynatrace Appmon. I have searched through the online docs for ways to accomplish this, but I have not found any clear direction on how this is done, my question was about finding documentation on how this should be done with Appmon.
Godfrey
1 comment Share
I think you will need create custom plugin in java. We are making such integrations for our clients, it's not so hard :) but I'm not familiar with this system.
https://www.dynatrace.com/support/doc/appmon/integrations-and-extensions/plugin-architecture/manage-and-develop-user-plugins/developing-a-user-plugin/
0 Likes 0 · ·
Sebastian K. avatar image
Sebastian K. answered ·
I think question is about sending alerts about incidents from Appmon. Yes there is such option, you can add action plugin to each incident you want. It can be sending request to jira, service now etc. but you will need those plugins so you have to look for them or write one. But there is couple of handy plugins in Dynatrace repository so go there :)
https://community.dynatrace.com/community/display/DL/FastPacks+and+Plugins
Share
Wolfgang B. avatar image
Wolfgang B. answered ·
Can you give more context on what you want to do? I read your question as sending events and problems from AppMon to Dynatrace through the API? Which is possible through the Dynatrace event REST API.
Wolfgang
Share
