question
Patricio B. avatar image
Patricio B. asked ·
appmon cpu utilization doubt
I'm trying to understand some cpu and GC metrics. For this purpose I will use the next example:
the upper chart has the metric "current CPU Load" by the agents living in the host "lnx-ssm-entrust-prod-aco-01". For the data point selected there is only two agents:
CurusmobileServer
IDGService
and here's my first question: the sum of the percentage of the two agents is 0,37% , but in the second chart the current cpu load of the host is 0.12%. does this mean that is a 37% of the 0.12%?
the same for the third chart. Is the total GC precentage 22,51% a percentage from 0.12%?
thanks
any extra clarify will be most appreciated
Patricio
dashboard7.2
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
You understand it right :)
1 comment Share
thanks! :)
0 Likes 0 · ·
