question
Nestor E. avatar image
Nestor E. asked ·
Differentiate two URIs at Application level
Suppose i have 2 server with 2 different application, but some "partial" uri are the same. IE:
http://SERVER_A/reports/fridayReport.pdf
http://SERVER_B/reports/fridayReport.pdf
I have a question about configuring the application.
This is the application configuration window, how do I differentiate the aplication in this case? I do not see the host name to differentiate them.
knowledge sharing
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Isn't better idea not to assign particular PDF report to application, but use hostname and split whole traffic from them into different applications?
1 comment Share
Hi Sebastian,
Yes i know it's a bad idea to do that, i should have post
Now, regarding your answer, where do i use the hostname to split the traffic from different applications? Can i use an URI with the hostname in the contains field?
0 Likes 0 · ·
