• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Sorin Z. · May 10, 2019 at 01:53 PM · Dynatrace Managed uem appmon 7 user session monitoring migration
instrumenting webserver with dynatrace and appserver with appmon
We have an issue with a client. They are in the process of migrating all of their monitoring from Appmon to Dynatrace.
We currently ran into a problem.
The setup is like this:
- they have Appmon running on Websphere 7.6 appservers which holds the old internetbanking
- they have developed and monitored with Dynatrace their new internet banking on different application servers
- all the application servers from above are being accessed through an IBM HTTP Server 8.5 webserver
- they have installed Oneagent on the webserver and visits in Appmon stopped working
- they tried migrating from Appmon to Oneagent on the Websphere 7.6 (which is out of support) and encountered random errors on a particular service; because of this we had to rollback.
We tried to:
- disable JS injection in Dynatrace so that it would not interfere with Appmon's js
- disabled monitoring from Websphere 7.6, restarted processes and uninstalled oneagent there
- reactivated Appmon java agent
Our hope was that, without JS injection, Appmon's js injection will work again.
Unfortunately not. Visits still don't show and moreover only a couple of calls on to the Websphere 7.6 are shown in Appmon.
Do any of you have similar experience on this matter?
Could we somehow monitor with UEM both old and new internetbanking apps(one with Appmon and the other with Dynatrace)?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Kyle K. · May 15, 2019 at 04:05 PM
Because the Web Server is handling the injection of the JS agent I would expect to see those visits showing up in your new Dynatrace instance instead of pulled in from App Mon. We have some integrations where purepaths can stitch between the 2 tools
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
32 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Dynatrace Real User Monitoring for applications with Classic Agents
Measure to capture javascript error message
will I be getting the bounce rate only if I create a visit based BT ?
Can we place sensor on Javascript method call?
CPU Usage Increase of Monitored Applications after Migration and Upgrade between Dynatrace AppMon 6.1 to 7.0.
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
