question
Nestor N. avatar image
Nestor N. asked ·
Is it expected behaviour for an application URL that is defined in a different system profile to appear as that Application in the purepath of a different system profile?
An application name that appears under the Purepaths dashlet "Application" column for System Profile_1 actually comes from an application URL that is defined in another profile (System Profile_2).
Is this expected behaviour?
Appmon version 7.1.22.
Nestor
appmonappmon 7purepathdashletsystem profile
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
If you are sure that there is no such rule in system profile you are looking at, it is possible that appmon is trying to connect somehow data between system profiles. But if you have systems that are communicating between themselves it is not good idea to split them between separate system profiles.
Share
