question
Karthika l. avatar image
Karthika l. asked ·
Dynatrace API/CSV to export and manipulate dashboard data to make charts/table
Do we have any open source tool which manipulates the dashboard data to make charts or tablular format.
appmondashboardDynatrace Managed
Karthika l. answered ·
@krunal Dave
Currently we are using jasper plugin to modify the dashboard data to provide report in desired output, which requires additional java coding effort.
We are in search of any open source tool integrated with dynatrace which reduces the coding effort
1 comment Share
Good question . It is interesting to know others have the same concern as me.
0 Likes 0 · ·
Krunal D. avatar image
Krunal D. answered ·
Hi Karthika,
For API standpoint there is no API which you can use to pull out data from dashboard. However, you can use time series API which can pull out data based on your dashboard measures.
Krunal Dave
1 comment Share
1 Like 1 · ·
